查看: 2093|回复: 0
高路华彩电B系列机型进入维修调试
发表于 2009-6-2 14:07:33 | 显示全部楼层 |阅读模式
高路华彩电B系列机型进入维修调试
1、进入"S"调试模式的方法,先将电视的声音调到"0",再按住电视机面板的"音量-"不放手,同时按住遥远器上的"屏显键",屏幕左上角出现一个"S"。即进入模式。这种模式只能调平常的参数,如白平衡、行和场的幅度和线性。如果要更换存储器,则需进入"D"模式。
2,进入"D"模式的方法。先进入"S"调试模式,然后用遥远器上的屏显键退出。再按住电视面板上的"音量-"不放,再按遥控器上的"屏显键",屏幕左上角出现"D",即进入此模式。
工厂模式数据表如(下表数据为TB机芯)
项目           &nbsp数据   &nbsp项目       &nbsp数据
RCUT            &nbsp20    &nbspVP50        &nbsp05
GCUT            &nbsp20     &nbspHIT        &nbsp33
BCUT            &nbsp20     &nbspHPS        &nbspFF
GDRV            &nbsp40    &nbspVP60        &nbsp01
BDRV            &nbsp40    &nbspHITS        &nbsp02
CNTX            &nbsp3F    &nbspVLIN        &nbsp0A
BRTC*           &nbsp48     &nbspVSC        &nbsp0C
COLC*           &nbsp40    &nbspVLIS        &nbsp00
TNTC*           &nbsp40    &nbspHITO        &nbsp19
COLP*           &nbsp20    &nbspHIT1        &nbsp00
COLS            &nbsp40     &nbspSBY        &nbsp08
SCNT            &nbsp0B     &nbspSRY        &nbsp08
CNTC*           &nbsp30    &nbspRAGC        &nbsp25
CNTN            &nbsp00     &nbspAFT        &nbsp40
BRTX            &nbsp30    &nbspHFTC        &nbsp00
BRTN            &nbsp30     &nbspV25        &nbsp25
COLX&nbspV50        &nbsp50  &nbspST3&nbspMOD1      &nbspE8
COLN&nbspBRTS       &nbsp00  &nbspSV3&nbspMOD2      &nbsp04
TXCX&nbspSELF&nbspCNTC  &nbsp23  &nbspST4&nbspSELF      &nbsp00
RGCN&nbspSELF&nbspTNTC  &nbsp00   &nbspVM1&nbspOSD      &nbsp07
SV4&nbspSELF&nbspVOC    &nbsp00  &nbspHPOS&nbspOPT      &nbsp07
SHPX&nbspSELF&nbspVGC   &nbsp69  &nbspTNTX&nbspVM2      &nbsp34
SHPN&nbspSELF&nbspBRTC  &nbsp75 &nbspTNTN&nbspMOD0      &nbsp03
VN0&nbspSELF&nbspCOL    &nbsp20
*表示该项目自动调整。
  &nbsp这个总线数据是新高路彩电中最有代表性的。比如说:TN-2955TD,TN-2998TB,TN-2593TB,TN-3486TC,TN-2992TB等机型。
LC863328A-5S15M8910 LA76810后期生产的2182TD,2187PLUS采用新一代CPU:M8910 TN2592AA,(2183TD),2183AA,2185AA,2155PLAS,(2187PLUS),2153AA,2181AA,2188AD,2192AA/LUSA,2581AA,2583AA/TD,2585AA,2586AA,2593AA,2593TDD 在频道和音量键之间有一个圆,在此加一个键即是TEST工厂键,或者把用户遥控器(芯片为SC7416-103)芯片(4),(13)脚短路,出现TEST进入,按数字键进入相应菜单。
SA机心:
(上海东杰) LC863320A-5S10 LA76810 2592TDD/2922TD,2992TDD,2522TD,2966AA,2922AA 按住键控板的"音量减"键直至"00"状态,同时按遥控器的屏显键进入S模式。(按菜单键7次,出现功能菜单,童锁设置为关时,显示黑屏。)
AB机心:
WINWIN2000V01 LA76810 2955AB,2988AB,2992AB 按遥控器返回键5秒,松开后立刻按遥控菜单键进入。童锁出厂密码为D0000。
AC机心:
LC863328A LA76810 2183AC,2192AC,2191AC,2153AC,2181AC:
频道和音量键之间有一个圆,在此加一个键即是TEST工厂键,如果遥控器芯片为SC7416-103把芯片(4),(13)脚短路,也可出现TEST进入,按数字键进入相应菜单。
AE WINWIN2K .V02(掩摸)M37225M8-103SP LA76810 2922AE,2952AE,2988AE,2988AEE,2969AE,2969AEE,2992AE,2956AE, 按遥控器返回键5秒,松开后立刻按遥控菜单键进入。退出按待机键,之后按0--3,按童锁后再按4--9,才可进入其它项,进行调试.注,工厂模式3里是调电压的.童锁出厂密码为D0000。
AG机心
LC863332A-5Y83MC8902A lA76810 2992AG,2955AG,2586AG,2193PLUS,2992AG,2592TDD 频道和音量键之间有一个圆,在此加一个键即是TEST工厂键,如果遥控器芯片为SC7416-103把芯片(4),(13)脚短路,也可出现TEST进入,按数字键进入相应菜单。
超级芯片TMP8803 TMP8803 2156PLUS2166PLUS 按住本机音量减不放,按遥控屏显键进入S,按招回,再按本机音量减键不放,同时按屏显进入D状态。注意8803有些后缀号不同不能代换。存储器可以用空白块,方法是断开24C08的(2)脚不接,开机后按本机频道键后,8803就会对存储器初始化写入基本数据。
PA机心 Z86227 OM8361 2191,2171,2183,2181,2591,2583,2571,2581(PA) 在频道减右侧加装一个RVICE键,按下该键,再快速按静音键进入。
PB机心
SA机心:
AB机心:
AC机心:
AG机心
PB机心
MTV880 OM8838 2589,2591,2962,2951,2955,2955TDD,2992TD,2952,2927(PB) 频道和音量键之间有一个圆,在此加一个键即是TEST工厂键,按此键进入。
PE机心 MTV880M37225M6MC8901A OM8839 2969,2999,2969PEE,2988,2988PEE,3486,2966,(PE) 按遥控器返回键5秒,松开后立刻按遥控菜单键进入。童锁出厂密码D0000,通用密码1011。
TB机心
87CK38N-1V50 TB1238N 2952,2953,2955,2955TD,2992,2988 按住本机音量减不放,按遥控屏显键进入S,按屏显键退出,再按本机音量减键不放,同时按屏显进入D状态。(按菜单及↑↓键选择童锁项目。)
TC机心 87CM38N-1P31 TB1240N 4318,3482,3486 同上TB机心。
MA
MC87012 M61201P 2986MA 按遥控循环键4秒以上,再立刻按MENC键,屏幕出现TEST,再按童锁键及4---9数字键进入相应菜单。按待机键,STANDBY键,TV进入READY状态,几秒字符消失退出工厂状态。
TMP87CK36IN-3370,TMP87CK36N;TMP87PM36N TA8880ANTA8776 TC2918、TC2961,TC3418 同时按下遥控器上F键与AV/TV键,再依次按动1键→0键→4键→8键,整机进入维修调整方式。维修方式的退出。或户遥控器芯片TC9028-021(15)脚二极管正极改接到(14)脚成为工厂遥控。[img]/qzone/em/e81.gif[/img][img]/qzone/em/e81.gif[/img]
GMT+8, 2025-7-21 12:45 , Processed in 0.220370 second(s), 16 queries .
