查看: 3018|回复: 0
全自动洗衣机控制系统的设计
发表于 2009-7-11 09:51:22 | 显示全部楼层 |阅读模式
摘要: 随着社会经济的发展和科学技术水平的提高,家庭电器全自动化成为必然的发展趋势。全自动洗衣机的产生极大的方便了人们的生活。洗衣机是国内家电业唯一不打价格战的行业,经过几年的平稳发展,国产洗衣机无论在质量上还是功能上都和世界领先水平同步。纵观洗衣机市场,高效节能、省水、省电、环保型洗衣机一直在市场上占主导地位。
该论文就怎样利用PLC来控制全自动洗衣机进行了调查,对其中软件设计、硬件设计等问题进行了分析和研究,实现了全自动洗衣机的正常运行和强制性停止功能。
关键词: PLC 全自动洗衣机 控制
Entire automatic washer control system design
Abstract: Along with the social economy development and the science and technology level enhancement, the family electric appliance entire automation becomes the inevitable development tendency. Entire automatic washer production enormous convenience peoples life. The washer is the domestic electrical appliances industry does not only hit the profession which the price fights, passes through several year steady development, the domestically produced washer regardless of in quality or in function all with world leading horizontal synchronization. Looks over the washer market, the highly effective energy conservation, the province water, the province electricity, the environmental protection washer continuously occupy the dominant position in the market. How does this paper study controls the entire automatic washer using PLC, to question and so on software design, hardware design has carried on the analysis and the discussion, has realized the entire automatic washer normal operation and compulsory stops the function.
Key word: PLC entire automatic washer control
目 录
第一章 概 述.......................................................1
第二章 课题任务分析................................................2
2.1 整体功能介绍................................................... 2
2.2 设备控制要求.....................................................2
第三章 控制系统的设计................................................3
3.1 控制系统的设计原则..................................................3
3.2  PLC I/O模块的选择步骤与原则 ....................................4
第四章 硬件电路设计................................................5
4.1 系统的选型...................................................5
4.2 PLC的工作原理及其结构功能......................................7
4.3 传感器的分类及其作用.....................................9
4.4 硬件接线图................................................10
第五章 软件的设计
5.1 I/O分配表.......................................................11
5.2 流程图.........................................................12
5.3 源程序..........................................................14
5.4 语句表........................................................15
5.5 梯形图........................................................18
5.4 程序运行过程分析...................................................23
5.5 程序的下载 安装和调试...............................................23
第六章 结束语..............................................................24
第七章 毕业设计总结........................................................25
致谢......................................................................26
参考文献..................................................................27
第一章 概 述
根据全自动洗衣机的工作原理,利用可编程控制器PLC实现控制,说明了PLC控制的原理方法,特点及控制洗衣机的特色。全自动洗衣机控制系统利用了三菱FX2N系列PLC的特点,对按鈕,电磁阀,开关等其他一些输入/输出点进行控制,实现了洗衣机洗衣过程的自动化。由于每遍的洗涤,排水,脱水的时间由PLC内计数器控制,所以只要改变计数器参数就可以改变时间。可以把上面设定的程序时间定下来,作为固定程序使用,也可以根据衣物的质地,数量及油污的程度来编程。只要稍作改变,就可以设计出诸如要多洗多甩的牛仔类衣物,轻洗轻甩的羊毛类衣物以及通用的标准洗涤程序,充分表现现代家电品的实用性。
在洗衣机控制方面,在PLC问世之前,工业控制领域中是继电器占主导地位。但继电器控制领域有着十分明显的缺点:体积大、耗电多、可靠性、寿命短、运行速度慢、适应性差、尤其当生产工艺发生变化时,就必须重新设计、重新安装,造成时间和资金的严重浪费。为了改变这一现状,PLC控制系统产生了。继1969年美国数字设备公司研制出世界第一台PLC,并在通用汽车公司自动装配线上试用,获得了成功,从而开创了工业控制新时期,从此,可编程控制器这一新的控制技术迅速发展起来了。在许多领域都有广泛的应用。PLC的 优点是:可靠性高,耗电少,适应性强,运行速度快,寿命长等,为了进一步提高全自动洗衣机的功能和性能,避免传统控制的一些弊端,就提出了用PLC来控制全自动洗衣机这个课题。
第二章 课题任务分析
2.1整体功能介绍
洗衣机的工作流程由进水,洗衣,排水,和脱水四个过程组成。在半自动洗衣机中,这四个过程分别用相应的按扭开关来控制。全自动洗衣机中,,这四个过程可做到全自动依次运行,直至洗衣结束。
2.2设备控制要求
全自动洗衣机控制要求是能实现”正常运行“和”强制停止“两种控制要求。
⑴按下启动按扭,开始进水直到水满(即水位达到高水位)时停止进水开始洗涤正转
⑵洗涤时,正转30秒,停3秒,然后反转30秒,停3秒
⑶如此循环5次,总共320秒开始排水
⑷水位下降到低水位时开始脱水并继续排水,脱水10秒
⑸开始清洗,重复(1)到(4),清洗3遍
⑹清洗完成,报警5秒并自动停机
⑺若按下排水按扭可以实现手动排水
⑻若按下停车按扭,可实现手动停止进水,排水 脱水及报警
第三章  控制系统的设计
3.1  控制系统的设计原则
    任何一种控制系统都是为了实现被控对象的工艺要求,以提高生产效率和产品质量。因此,在设计PLC控制系统时,应遵循以下基本原则:
1. 最大限度地满足被控对象的控制要求
充分发挥PLC的功能,最大限度地满足被控对象的控制要求,是设计PLC控制系统的首要前提,这也是设计中最重要的一条原则。这就要求设计人员在设计前就要深入现场进行调查研究,收集控制现场的资料,收集相关先进的国内、国外资料。同时要注意和现场的工程管理人员、工程技术人员、现场操作人员紧密配合,拟定控制方案,共同解决设计中的重点问题和疑难问题。
2. 保证PLC控制系统安全可靠
保证PLC控制系统能够长期安全、可靠、稳定运行,是设计控制系统的重要原则。这就要求设计者在系统设计、元器件选择、软件编程上要全面考虑,以确保控制系统安全可靠。例如:应该保证PLC程序不仅在正常条件下运行,而且在非正常情况下(如突然掉电再上电、按钮按错等),也能正常工作。
3. 力求简单、经济、使用及维修方便
一个新的控制工程固然能提高产品的质量和数量,带来巨大的经济效益和社会效益,但新工程的投入、技术的培训、设备的维护也将导致运行资金的增加。因此,在满足控制要求的前提下,一方面要注意不断地扩大工程的效益,另一方面也要注意不断地降低工程的成本。这就要求设计者不仅应该使控制系统简单、经济,而且要使控制系统的使用和维护方便、成本低,不宜盲目追求自动化和高指标。
4. 适应发展的需要
    由于技术的不断发展,控制系统的要求也将会不断地提高,设计时要适当考虑到今后控制系统发展和完善的需要。这就要求在选择PLC、输入/输出模块、I/O点数和内存容量时,要适当留有裕量,以满足今后生产的发展和工艺的改进。
3.2.1 PLC I/O模块的选择步骤与原则
一般I/O模块的价格占PLC价格的一半以上。PLC的I/O模块有开关量I/O模块、模拟量I/O模块及各种特殊功能模块等。不同的I/O模块,其电路及功能也不同,直接影响PLC的应用范围和价格,应当根据实际需要加以选择。
3.2.2 开关量I/O模块的选择
(1) 开关量输入模块的选择
开关量输入模块是用来接收现场输入设备的开关信号,将信号转换为PLC内部接受的低电压信号,并实现PLC内、外信号的电气隔离。选择时主要应考虑以下几个方面:
(a)输入信号的类型及电压等级
开关量输入模块有直流输入、交流输入和交流/直流输入三种类型。选择时主要根据现场输入信号和周围环境因素等。直流输入模块的延迟时间较短,还可以直接与接近开关、光电开关等电子输入设备连接;交流输入模块可靠性好,适合于有油雾、粉尘的恶劣环境下使用。
开关量输入模块的输入信号的电压等级有:直流5V、12V、24V、48V、60V等;交流110V、220V等。选择时主要根据现场输入设备与输入模块之间的距离来考虑。一般5V、12V、24V用于传输距离较近场合,如5V输入模块最远不得超过10米。距离较远的应选用输入电压等级较高的模块。
b)输入接线方式
开关量输入模块主要有汇点式和分组式两种接线方:
1)汇点式输入    2)分组式输入
汇点式的开关量输入模块所有输入点共用一个公共端(COM);而分组式的开关量输入模块是将输入点分成若干组,每一组(几个输入点)有一个公共端,各组之间是分隔的。分组式的开关量输入模块价格较汇点式的高,如果输入信号之间不需要分隔,一般选用汇点式的。
c)注意同时接通的输入点数量
对于选用高密度的输入模块(如32点、48点等),应考虑该模块同时接通的点数一般不要超过输入点数的60%。
d)输入门槛电
为了提高系统的可靠性,必须考虑输入门槛电平的大小。门槛电平越高,抗干扰能力越强,传输距离也越远,具体可参阅PLC说明书。
(2)开关量输出模块的选择
开关量输出模块是将PLC内部低电压信号转换成驱动外部输出设备的开关信号,并实现PLC内外信号的电气隔离。选择时主要应考虑以下几个方面:
a)输出方式
开关量输出模块有继电器输出、晶闸管输出和晶体管输出三种方式。
继电器输出的价格便宜,既可以用于驱动交流负载,又可用于直流负载,而且适用的电压大小范围较宽、导通压降小,同时承受瞬时过电压和过电流的能力较强,但其属于有触点元件,动作速度较慢(驱动感性负载时,触点动作频率不得超过1HZ)、寿命较短、可靠性较差,只能适用于不频繁通断的场合。
对于频繁通断的负载,应该选用晶闸管输出或晶体管输出,它们属于无触点元件。但晶闸管输出只能用于交流负载,而晶体管输出只能用于直流负载。
b)输出接线方式
开关量输出模块主要有分组式和分隔式两种接线方式:
  1)分组式输出   2)分隔式输出
分组式输出是几个输出点为一组,一组有一个公共端,各组之间是分隔的,可分别用于驱动不同电源的外部输出设备;分隔式输出是每一个输出点就有一个公共端,各输出点之间相互隔离。选择时主要根据PLC输出设备的电源类型和电压等级的多少而定。一般整体式PLC既有分组式输出,也有分隔式输出。
c)驱动能力
  开关量输出模块的输出电流(驱动能力)必须大于PLC外接输出设备的额定电流。用户应根据实际输出设备的电流大小来选择输出模块的输出电流。如果实际输出设备的电流较大,输出模块无法直接驱动,可增加中间放大环节。
d)注意同时接通的输出点数量
选择开关量输出模块时,还应考虑能同时接通的输出点数量。同时接通输出设备的累计电流值必须小于公共端所允许通过的电流值,如一个220V/2A的8点输出模块,每个输出点可承受2A的电流,但输出公共端允许通过的电流并不是16A(8×2A),通常要比此值小得多。一般来讲,同时接通的点数不要超出同一公共端输出点数的60%。
  e)输出的最大电流与负载类型、环境温度等因素有关
开关量输出模块的技术指标,它与不同的负载类型密切相关,特别是输出的最大电流。另外,晶闸管的最大输出电流随环境温度升高会降低,在实际使用中也应注意。
3.3.2模拟量I/O模块的选择
  模拟量I/O模块的主要功能是数据转换,并与PLC内部总线相连,同时为了安全也有电气隔离功能。模拟量输入(A/D)模块是将现场由传感器检测而产生的连续的模拟量信号转换成PLC内部可接受的数字量;模拟量输出(D/A)模块是将PLC内部的数字量转换为模拟量信号输出。
  典型模拟量I/O模块的量程为-10V~+10V、0~+10V、4~20mA等,可根据实际需要选用,同时还应考虑其分辨率和转换精度等因素。
  一些PLC制造厂家还提供特殊模拟量输入模块,可用来直接接收低电平信号(如RTD、热电偶等信号)。
3.3.4特殊功能模块的选择
目前,PLC制造厂家相继推出了一些具有特殊功能的I/O模块,有的还推出了自带CPU的智能型I/O模块,如高速计数器、凸轮模拟器、位置控制模块、PID控制模块、通信模块等。
GMT+8, 2025-7-7 15:42 , Processed in 3.108067 second(s), 16 queries .
