查看: 1535|回复: 0
巴适的耳机
发表于 2009-7-4 01:41:15 | 显示全部楼层 |阅读模式
ATH-ANC7
铁三角ATH-ANC7是一款典型的主动降噪耳机,采用了QuietPoint? 有源反向降噪技术,通过两边耳罩上的微型收音头,接收环境噪音,再通过内部的对冲电路把噪音降低,按照官方标称,它最大能将外界噪音降低22dB,这个效果已经非常不错了。其实这个技术与森海塞尔的降噪专利“NoiseGard”系统原理类似。
ATH-ANC7 铁三角ATH-ANC7降噪耳机
TWO BOSE QuietComfort
On-ear fit: Earcups rest gently on your ears
Bose? noise reduction and quality sound for travel, work and home
Comfortable, lightweight headphone design
Rechargeable lithium-ion battery: 25 hours average use per charge
Fold-flat earcups for easy storage in slim carrying case
TriPort声学结构设计
III Shure Shure
Features Sound Isolating earphones coupled with VoicePort microphone and a milti-function control switch. Listen to music or talk on your cell phone - all with the same headset WideBand MicroDriver technology generates detailed highs and enhanced bass.
Sensitivity: 115dB with 26 ohms impedance
Fit kit for personalized, comfortable in-ear fit
ONKYO
安桥TX-NR801及TX-NR901具备THX Select的电影院音效标准,同时拥有先进的7.1声道放大系统,NR801为7×160W等功率输出,NR901为7×180W等功率输出,均采用大电流输出设计,能对困难的音箱提供出色的驱动力。
ONKYO ONKYO ONKYO ONKYO ONKYO
Madonna Ciccone 1958
Madonna Louise Veronica Ciccone
I stand for freedom of expression,doing what you believe in,and going after your dreams.
我主张言论自由,做你认为正确的事,追寻你心中的梦想。
Madonna
Never forget to get dream.
永远不要忘记去梦想。
Madonna
To be brave is to love someone unconditionally,without expecting anything in return.To just give.That takes courage,because we dont want to fall on our faces or leave ourselves open to hurt.
GMT+8, 2024-5-3 10:14 , Processed in 0.175098 second(s), 9 queries , File On.
