查看: 1960|回复: 0
如何开启和关闭LINUX 防火墙
发表于 2009-6-2 20:13:13 | 显示全部楼层 |阅读模式
LINUX 放火墙的开启和关闭命令是什么? 如何查看防火墙是否安装和配置情况?
解决办法:
关闭: /etc/rc.d/init.d/iptables stop
启动: /etc/rc.d/init.d/iptables start
查看当前配置:iptables -L
Linux下关闭和开启防火墙
1) 重启后生效
开启: chkconfig firewall on
关闭: chkconfig firewall off
2) 即时生效,重启后失效
开启: service iptables start
关闭: service iptables stop
需要说明的是对于Linux下的其它服务都可以用以上命令执行开启和关闭操作。
在开启了防火墙时,做如下设置,开启相关端口,
修改etcsysconfigiptables 文件,添加以下内容:
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 80 -j ACCEPT
-A RH-Firewall-1-INPUT -m state --state NEW -m tcp -p tcp --dport 22 -j ACCEPT
默认安装linux后(防火墙是开启状态),此时防火墙没有开放1521端口,使得Oracle的客户端无法连接服务器。此时或者关闭防火墙,或者设置防火墙开放1521端口。
1.检查iptables的状态使用命令 service iptables status
[img]/qzone/newblog/v5/editor/css/loading.gif[/img][root@pcmxexweb ~]# service iptables status
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]表格:filter
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]Chain INPUT (policy ACCEPT)
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]num  target     prot opt source               destination
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]1    RH-Firewall-1-INPUT  all  --  0.0.0.0/0            0.0.0.0/0
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]Chain FORWARD (policy ACCEPT)
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]Chain OUTPUT (policy ACCEPT)
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]Chain RH-Firewall-1-INPUT (2 references)
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]1    ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]2    ACCEPT     icmp --  0.0.0.0/0            0.0.0.0/0           icmp type 255
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]3    ACCEPT     esp  --  0.0.0.0/0            0.0.0.0/0
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]4    ACCEPT     ah   --  0.0.0.0/0            0.0.0.0/0
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]5    ACCEPT     udp  --  0.0.0.0/0            224.0.0.251         udp dpt:5353
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]6    ACCEPT     udp  --  0.0.0.0/0            0.0.0.0/0           udp dpt:631
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]7    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           tcp dpt:631
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]8    ACCEPT     all  --  0.0.0.0/0            0.0.0.0/0           state RELATED,ESTABLISHED
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]9    ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:22
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]10   ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:23
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]11   ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:80
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]12   ACCEPT     tcp  --  0.0.0.0/0            0.0.0.0/0           state NEW tcp dpt:443
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]13   REJECT     all  --  0.0.0.0/0            0.0.0.0/0           reject-with icmp-host-prohibited
#说明防火墙当前是开启状态,并开放了22,23,80,443端口
2.关闭防火墙使用命令 service iptables stop
[img]/qzone/newblog/v5/editor/css/loading.gif[/img][root@pcmxexweb ~]# service iptables stop
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]清除防火墙规则:                                           [确定]
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]把 chains 设置为 ACCEPT 策略:filter                       [确定]
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]正在卸载 Iiptables 模块:                                  [确定]
3.开启防火墙
使用命令 service iptables start
[img]/qzone/newblog/v5/editor/css/loading.gif[/img][root@pcmxexweb ~]# service iptables start
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]应用 iptables 防火墙规则:                                 [确定]
[img]/qzone/newblog/v5/editor/css/loading.gif[/img]载入额外 iptables 模块:ip_conntrack_netbios_ns            [确定]
4.设置开机启动防火墙
使用命令 ntsysv
[img]/qzone/newblog/v5/editor/css/loading.gif[/img][root@pcmxexweb ~]# ntsysv
将会出现图形界面,在其中选中iptables。确认。
5.简单配置防火墙规则
[img]/qzone/newblog/v5/editor/css/loading.gif[/img][root@pcmxexweb ~]# setup
选择 防火墙配置--》定制--》在“其他端口”中输入要开放的端口 如:1521
http://www.zznj.com/linux/index.html
GMT+8, 2025-7-4 09:05 , Processed in 0.201531 second(s), 16 queries .
