查看: 1762|回复: 0
厦华彩电CRT电视遥控器代码对照表
发表于 2009-6-2 14:01:53 | 显示全部楼层 |阅读模式
RC-D04(F44)(N3430)
5653T ,6688T ,6698T ,7120T ,7120TZ ,7120TK ,7103T ,
7103TA ,7103K ,7698T ,7698TZ ,7698TR ,7128TE
RC-E03(TMP47C432) 5103 ,5103P ,5103N
RC-E04(UPC1362) 3702 ,3751B ,5102
RC-E05(M491) 5125 ,5125P ,5125S
RC-E06(TMP47C634-2465) 3751 ,5140 ,3902 ,5103DA
RC-F01(TMP47C634-2465) 3781A ,1020 ,1020S ,3902 ,5140E ,5622 ,7102
RC-F03(M34300) 6698TH ,7698TH
RC-F05(TMP47C634-384)
3770RN ,3770RC ,3770RZ ,5160RZ ,5160RC ,5160RN ,
5160RR ,5170RZ ,5170RK ,5180RZ ,5150R ,5140R ,5650R ,
5660RC ,5660RZ ,5660RR ,5660RN ,5670RZ/RR ,5680RC ,
5680RN ,5680RK ,5680RR ,5680RZ ,5690RZ ,5150R ,5140R
RC-F16(ST6387) 5661T ,5670RT ,5680RA ,5680RT ,3771 ,5161 ,5170RJ
RC-F20(TMP47C634-384) 3770R ,5160R ,5660R ,5680R
RC-F21 F21Y
RC-F22(KY88C94) 6667T ,6687TZ ,7120TA ,7698TA ,7687T
RC-F27(KY88C94) 6668T ,6688 ,7128TK ,7688TK
RC-F31(F42)(M37211)
3770RF ,5160RF ,5170RF ,5180RF ,2180 ,5680RF ,5670RF ,
5690RF ,5660RF ,6687TJ ,2550 ,2550J ,2570/J ,6667TJ ,
6687TN ,6667TN
RC-F36(KY88C94) 7688T ,7688TG ,7128T
RC-F45(KY88C94) 6687TG ,7687TG
RC-F46(M37211) 6688T ,6668TL ,6668TM ,7688TV ,7688TM ,7688TL
RC-F47(M37211)
6667TL ,6667TM ,7687TL ,7687TM ,7668TV ,7668TM ,
6687T
RC-F49 6687TL ,7687TL
RC-F51(N)(TMP47C634-RC18)
1470N ,2160I ,2180I ,2190I ,5660RY ,5660RR ,5670RY ,
5670RR ,5680RY ,5680RR ,5690RY ,5690RR ,2170N ,2170I ,
2190N ,21A0N ,21A0I ,2180N ,2160N ,2160I
RC-F52(WST98A01) 6687TB ,7687TB ,6667TB
RC-F54(WST98A01) 7688T ,7688TG
RC-F56(N)(ST6368 或6378)
1470 ,1470F ,1470FN ,14HO ,14HON ,2197 ,2797II ,
21K8 ,5670RX ,5680RX ,2190 ,2160 ,2180 ,2170 ,2170N ,
2170I ,21A0 ,21A0N ,21A0I ,21K8 ,2570II ,2560N ,
2570N ,2580N ,2590N ,2980II ,2970N ,2970II ,2980N ,
29K8N ,29K8II ,29K8III ,2950N ,2960N ,2990N ,2990GM
RC-F57(WST98A01) 7687TG
RC-F59(K18)(TV222-PR) 2560 ,2570 ,2580 ,2950 ,2960 ,2970 ,2980
RC-F60(ST9291 或ST9) 2197 ,2197 ,2197R
RC-F61(ST6378) 2570II ,2580II ,2590II,2950II ,2960II ,2990II
RC-F72(ST6378) 2570I ,2580I ,2950I ,2970I ,2990I
RC-F89 F2120K ,J2130F/IZ ,F2122II
RC-F74(M37211) 2560N ,2570N ,2580N
RC-F82(LC863320A) 21A6NC ,21A6NCB ,F2116,A2116B ,2196NC ,2196NCB ,
更多彩电维修资料请到《彩电维修资料网》http://www.tv160.com 查询!
RC-H19(TPM47C634-2465) 5140R ,5150R
RC-K03(KY88C94) 7669T
RC-K06(M37211) 6687TLW ,7688TMW ,7687TMW
RC-K07(N)(TM87CK36)
7662T ,2978T ,2978TB ,2968T ,3468T ,3468TB ,3868T ,
3868TB ,3478TB ,3878TB
RC-K15(TM87CK36) 2922T/TS
RC-K25(K36N)(TMP87DM36 或CTS-860) 29F8THD ,3478THD ,34F8THD ,3878THD
RC-K21(TMP87CM38-3645N)
21A5T ,21A5TJ ,2195T ,2195TJ ,21F8T ,2555T ,258AT ,
258ATJ ,259AT ,259ATJ ,2958TII ,2965T ,297AT ,297ATJ ,
296AT ,296ATJ ,299AT ,299ATJ ,29AAT ,29AATJ ,3465T,
3465TJ ,29FATV ,3485TJ ,A217
RC-K26(N)(TMP87CK36 或CTS-8602) 25F8TD,2958TU ,2998TD ,2978TD ,29F8TD ,29E8TD ,34F8TD,
34E8TD
RC-K27(N)(TMP87CK36 或CTS-860)
25E8TBV ,25F8TBV ,2998T ,2998TV ,2998TBV ,2998TB ,
2958T("华厦一列"系列),2978TV ,2978TBV ,29F8TBV ,
29A8TBV ,34E8TBV ,34L8TBV,3488TBV ,3468TV/TBV ,
3478TBV ,34F8TBV ,3498TBV ,3868TV/TBV
RC-K28(TMP87CK36) 2958T("福满堂"系列)
RC-K30(N)(K11)(CTS-860)
2978TH ,2978TS ,2978THB ,2998TH ,2998THB ,3468TH ,
3468TS ,3468THB ,3478TH ,3478THB ,34F8TH ,3868TH ,
3868THB ,3878TH ,3878THB ,3878TSB
RC-K34(N)(CTS-860) 2998TQ ,3488TQ
RC-ESHD 用户(P83C266BDR-42) 29D8M
RC-K36N 29F8THD ,34F8THD ,3478THD ,3878THD
RC-K45(TMP87PS38)
21F8T/TJ ,256ATJ ,25FAT ,25FATC ,25FATCJ ,25FATJ ,
255ATC ,255ATCJ ,257ATJ ,258ATJ ,259ATJ ,A2515 ,
A2516 ,29EATVC ,29EATV,29EATVCJ ,29EATVJ ,29EATVC ,
29FATV ,29FATVJ ,29FATVCJ ,295ATJ ,29LATVCJ ,29LATVC ,
297ATC ,297ATCJ ,299ATCJ ,299ATC ,299AGM ,34LATJE ,
A2923 ,293ATK ,299ATK
RC-K46(KS2501B) 29F6TD
RC-K48 XT-2955T ,KTV-2102
RC-K50 R299
RC-K54 S2516 ,S251,S2916 ,S293
RC-K56(M37221) R2516,R2916
RC-K57 S34L
RC-K58/N(CTS-763)
A253 ,A2916 ,A293 ,A34E ,A34L ,A346 ,A348 ,A349
RC-K59——S2917I ,S2937,S34LI,S2937B
RC-K61N N293B ,N2932 ,N34FYB ,N3431A
RC-K63(K88C4504) S2915 ,S2925 ,S34LI,S3417 ,S2955C ,S2958 ,S2955
RC-K70N N3431H
RC-K72N N3430D
RC-N02N(LC863320A) F21Y,F14Y
RC-N05/N(LC863248) E2517,E2530 ,E2531,E2519 ,E2520 ,E2535
RC-R02 J2119,J2130A/N ,J2126N ,J2130N ,J2131,J2119K ,J2131P
RC-R03 R2920,R2938(K62N 通用)
RC-R18 Y3416,Y3430
RC-R09 R2920A,R2938A
RC-R17 Y3430,Y2921
RC-S02 S2925II ,S2938II
RC-S05 V2939 ,V3426 ,V2951 ,V328
RC-S09 S2935III ,S2935V ,S3435III/V,S2935VI ,S2925V,S2939VIII
RC-S16 V2951W
RC-S14-0A(TMPA8807) RC-M18
W2915 ,W2916,W2935,N3430W ,N3431W ,W3431 ,W3416,
W3431 MT2928 ,MT3418 ,MT2951 ,MT2975 ,MT3451 ,MT2971
RC-A07 TS2130 ,TS2135
RC-A18 TS2150
RC-G02(M37225) U2928 ,U3418 ,U34FI ,U29FI
RC-G03(M37225) 3281D ,3681D ,3261D
RC-G06 HT-3281H
RC-G08(WT60P1) 34F1/A ,2981/A ,29F1/A ,2981S
RC-G09 GU29F1 (万利达)
RC-G18 HT-3261E ,HT3661E
RC-S15 V2951W ,V3451W
RC-Q03 A2923 ,A2921
RC-Q04
E2930/K ,E2931,E2963,E2938/E ,E2921 ,E2965/K ,R2938E ,
E2919
RC-Q05
A2120/J ,A21FJ ,A2520 ,A2921B ,A2929B ,A2923B ,A3416 ,
A2929P ,A2916 ,A253B
RC-Q13 M2135
RC-Q15 M2126,M2526 维修RC
RC-Q16 M2126,M2150K ,M2526 ,M2130
RC-Q20 TF2955H
RC-Q25 MT2935A ,TF2955A ,MT3435A
RC-T01 K2926 ,K2918
RC-C02 HT-3281T ,2966T ,3466T
RC-C03 MT-2926M,MT-2968M ,MT-2971M ,MT-3468M
RC-C07 TR2978
RC-V08 TN2985 ,TN3483
AD-18 电源适配器(302-0AD18-00) 1020S
JME-8561(PPM4) 键盘(303-10001-02) MT-3481G ,HT-3281W ,HT-3681W
JME-8561 键盘(303-10001-01)
HT-3281SW ,HT-3281LW ,HT-3281LW ,HT-3681SWV2951W ,
V3451W
备注:1,N02 ,N02N 遥控印制板不能通用.2,R2938 维修RC 为K56,R2938A 维修RC 为K25 或
K36N 2,S09 有二种印制板:IC 大块为东芝,IC 小块为飞利浦
GMT+8, 2024-5-16 14:34 , Processed in 0.169507 second(s), 9 queries , File On.
