查看: 2671|回复: 0
解决Windows 7右键“管理”没有反应的方法(修复文件下载)
发表于 2009-10-15 09:41:34 | 显示全部楼层 |阅读模式
此注册表文件是用来解决WIN7右键"管理"无反应的,你也可以自己新建一个文本,然后把如下代码复制粘贴到文本中,保存为**.reg,然后右键合并即可!
  1. Windows Registry Editor Version 5.00
  2. [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage]
  3. @=hex(2):40,00,25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,6f,00,74,\
  4. 00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
  5. 79,00,63,00,6f,00,6d,00,70,00,75,00,74,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,\
  6. 00,34,00,30,00,30,00,00,00
  7. "MUIVerb"=hex(2):40,00,25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,\
  8. 6f,00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
  9. 00,6d,00,79,00,63,00,6f,00,6d,00,70,00,75,00,74,00,2e,00,64,00,6c,00,6c,00,\
  10. 2c,00,2d,00,34,00,30,00,30,00,00,00
  11. "SuppressionPolicy"=dword:4000003c
  12. "HasLUAShield"=""
  13. [HKEY_CLASSES_ROOT\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}\shell\Manage\command]
  14. @=hex(2):25,00,77,00,69,00,6e,00,64,00,69,00,72,00,25,00,5c,00,73,00,79,00,73,\
  15. 00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,6d,00,63,00,2e,00,65,00,78,00,\
  16. 65,00,20,00,2f,00,73,00,20,00,25,00,77,00,69,00,6e,00,64,00,69,00,72,00,25,\
  17. 00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,63,00,6f,00,\
  18. 6d,00,70,00,6d,00,67,00,6d,00,74,00,2e,00,6d,00,73,00,63,00,00,00<!--++ plugin_code qcomic begin--> <!--++ plugin_code qcomic end-->
复制代码
解决Windows 7右键点击“管理”没有反应.rar (541 Bytes, 下载次数: 3)
GMT+8, 2025-5-1 12:58 , Processed in 0.213259 second(s), 18 queries .
