查看: 3247|回复: 2
Discuz!7.0 注册增加必填信息:QQ,性别 ,来自,手工添加代码方法
发表于 2009-1-20 02:11:49 | 显示全部楼层 |阅读模式
打开:\templates\default\css_float.htm
查找:
  1. .loginform { float: left; overflow: auto; margin-bottom: 10px; *margin-bottom: -10px; padding-top: 20px; width: 285px; height: 210px; border-right: 1px solid {CONTENTSEPARATE}; }
复制代码
替换成:
  1. .loginform { float: left; overflow: auto; margin-bottom: 10px; *margin-bottom: -10px; padding-top: 20px; width: 270px; height: 210px; border-right: 1px solid {CONTENTSEPARATE}; }
复制代码
查找:
  1. .loginform label em, .fsubmit em { float: left; width: 60px; }
复制代码
在下面添加:
  1. .logininfo label em { float: left; width: 40px; }
复制代码
查找:
  1. .logininfo { float: left; overflow: hidden; margin-left: 60px; width: 195px; height: 210px; }
复制代码
替换成:
  1. .logininfo { float: left; overflow: hidden;margin-left: 10px; width: 265px; height: 210px; }
  2.                   .logininfo label { clear: both; overflow: hidden; display:block; margin: 0 0 10px; line-height: 22px; }
复制代码
打开:\templates\default\register.htm
查找:
  1. <div class="logininfo singleinfo">
复制代码
替换成:
  1.    <div class="logininfo regform">
  2.       <label><em>QQ:</em><input type="text" id="newqq" name="newqq" autocomplete="off" size="25" maxlength="15" value="" tabindex="1" class="txt" /> *</label>
  3.        <label><em>{lang location}:</em><input type="text" name="locationnew" id="locationnew" size="25" value="$member[location]" tabindex="1" class="txt" /> *</label>
  4.        <label><em>{lang gender}:</em><input type="radio" name="newgender" value="1" tabindex="1" /> {lang male} <input type="radio" name="newgender" value="2" tabindex="1" /> {lang female} <font color="#006699"> 请选择性别</font> *</label>
复制代码
打开:register.php
查找:
  1.   if(!$password || $password != addslashes($password)) {
  2.    showmessage('profile_passwd_illegal');
  3.   }
复制代码
在下面添加:
  1.   if($newqq == '') {
  2.   showmessage('profile_qq_illegal');
  3.   }
  4.   if($locationnew == '') {
  5.   showmessage('profile_locationnew_illegal');
  6.   }
  7.   if(!($newgender == '1' || $newgender == '2')) {
  8.   showmessage('profile_gendernew_invalid');
  9. }
复制代码
继续往下查找:
  1. $db->query("INSERT INTO {$tablepre}members (uid, username, password, secques, adminid, groupid, regip, regdate, lastvisit, lastactivity, posts, credits, extcredits1, extcredits2, extcredits3, extcredits4, extcredits5, extcredits6, extcredits7, extcredits8, email, showemail, timeoffset, pmsound, invisible, newsletter)
  2.   VALUES ('$uid', '$username', '$password', '$secques', '0', '$groupinfo[groupid]', '$onlineip', '$timestamp', '$timestamp', '$timestamp', '0', $initcredits, '$email', '0', '9999', '1', '$invisiblenew', '1')");
  3. $db->query("REPLACE INTO {$tablepre}memberfields (uid, authstr $fieldadd1) VALUES ('$uid', '$authstr' $fieldadd2)");
复制代码
替换成:
  1. $db->query("INSERT INTO {$tablepre}members (uid, username, password, secques, adminid, groupid, regip, regdate, lastvisit, lastactivity, posts, credits, extcredits1, extcredits2, extcredits3, extcredits4, extcredits5, extcredits6, extcredits7, extcredits8, email, showemail, timeoffset, pmsound, invisible, newsletter, gender)
  2.   VALUES ('$uid', '$username', '$password', '$secques', '0', '$groupinfo[groupid]', '$onlineip', '$timestamp', '$timestamp', '$timestamp', '0', $initcredits, '$email', '0', '9999', '1', '$invisiblenew', '1', '$newgender')");
  3. $db->query("REPLACE INTO {$tablepre}memberfields (uid, qq, location, authstr $fieldadd1) VALUES ('$uid', '$newqq', '$locationnew', '$authstr' $fieldadd2)");
复制代码
打开:\templates\default\messages.lang.php
  查找:
  1. 'profile_email_domain_illegal' => 'Email 包含不可使用的邮箱域名',
复制代码
  在下边加上:
  1. 'profile_qq_illegal' => 'QQ号码未填写,请返回重新填写。',
  2. 'profile_locationnew_illegal' => '所在的地区未填写,请返回重新填写。',
  3. 'profile_gendernew_invalid' => '性别未填写,请返回重新填写。',
复制代码
  最后进入后台更新缓存就可以了
如果要和附件图片一样的效果还要做下面这一步(本站就不放图片了):
打开:css_script.htm
适当调整下边这个变量的参数即可:
  1. <!--{if $secqaacheck}-->
复制代码
此帖发布在discuz!官方的地址:http://www.discuz.net/thread-1196189-1-1.html
发表于 2009-1-23 10:23:01 | 显示全部楼层
、、好深奥。。昨天我在discuz后台添加勒个自定义flash。。。差点睡不着。。
回复
使用道具 举报
 楼主| 发表于 2009-1-24 15:26:44 | 显示全部楼层
FLASH按扭有的呀
回复
使用道具 举报
GMT+8, 2025-5-3 12:25 , Processed in 0.235642 second(s), 17 queries .
