维修人员
扫一扫,访问微社区
查看: 763|回复: 0
[二极管] (肖基特二极管)高效整流二极管参数表
发表于 2009-6-1 09:58:30 | 显示全部楼层 |阅读模式
您需要 登录 才可以下载或查看,没有帐号?注册
x
高效整流二极管 HIGH EFFICIENCY RECTIFIERS
类型TYPE最大反向峰值 电 压Maximum Peak Reverse Voltage
最大半波整流电流50HZMaximum Average Rectified Current at Half-wave Resistive load 50HZ最大正向峰值 浪涌电流50HZMaximum Forward Peak Surge Current 50HZ Superimposed最大反向电流 PRV. TA=25℃Maximum Reverse Current at PRV and TA=25℃最大正向电压 在TA=25℃ Maximum Forward Voltage at TA=25℃最大反向恢复 时 间 Maximum Reverse Recovery time外型 Package
PRVIo at TAIFSMIRIFMVFM
VA
AμAAV
HER101501503051150DO-41
HER1021001503051150DO-41
HER10320015030511.350DO-41
HER10430015030511.350DO-41
HER10540015030511.350DO-41
HER10660015030511.8570DO-41
HER10780015030511.8570DO-41
HER108100015030511.8570DO-41
HER151501.5506051.5150DO-15
HER1521001.5506051.5150DO-15
HER1532001.5506051.5150DO-15
HER1543001.5506051.51.350DO-15
HER1554001.5506051.51.350DO-15
HER1566001.5506051.51.770DO-15
HER1578001.5506051.51.770DO-15
HER201502506052150DO-15
HER2021002506052150DO-15
HER2032002506052150DO-15
HER20430025060521.350DO-15
HER20540025060521.350DO-15
HER20660025060521.8570DO-15
HER20780025060521.8570DO-15
HER208100025060521.8570DO-15
HER30150350150103150DO-27
HER302100350150103150DO-27
HER303200350150103150DO-27
HER3043003501501031.350DO-27
HER3054003501501031.350DO-27
HER3066003501501031.8570DO-27
HER3078003501501031.8570DO-27
HER30810003501501031.8570DO-27
HER60150650300106150R-6
HER602100650300106150R-6
HER603200650300106150R-6
HER6043006503001061.350R-6
HER6054006503001061.350R-6
HER6066006503001061.770R-6
HER6078006503001061.770R-6
UF1015015530510.9550DO-41
UF10210015530510.9550DO-41
UF10320015530510.9550DO-41
UF10430015530510.9550DO-41
UF10540015530511.1550DO-41
UF10660015530511.1550DO-41
UF10780015530511.450DO-41
UF151501.5555051.50.9550DO-15
UF1521001.5555051.50.9550DO-15
UF1532001.5555051.50.9550DO-15
UF1543001.5555051.50.9550DO-15
UF1554001.5555051.51.1550DO-15
UF1566001.5555051.51.1550DO-15
UF1578001.5555051.51.450DO-15
UF2015025570520.9550DO-15
UF20210025570520.9550DO-15
UF20320025570520.9550DO-15
UF20430025570520.9550DO-15
UF20540025570521.1550DO-15
UF20660025570521.1550DO-15
UF20780025570521.450DO-15
UF301503551001030.9550DO-27
UF3021003551001030.9550DO-27
UF3032003551001030.9550DO-27
UF3043003551001030.9550DO-27
UF3054003551001031.1550DO-27
UF3066003551001031.1550DO-27
UF3078003551001031.450DO-27
UF4001501553051150D0-41
UF40021001553051150D0-41
UF40032001553051150D0-41
UF40044001553051150D0-41
UF540050355150103150DO-27
UF5401100355150103150DO-27
UF5402200355150103150DO-27
UF5403300355150103150DO-27
UF5404400355150103150DO-27
UF5405500355150103150DO-27
UF54066003551501031.775DO-27
UF54078003551501031.775DO-27
UF540810003551501031.775DO-27
QQ|Archiver|手机版|小黑屋|维修人员 ( 鲁ICP备17033090号 )
GMT+8, 2019-2-17 19:39 , Processed in 0.091630 second(s), 7 queries , File On.
Powered by Discuz! X3.4
© 2001-2017 Comsenz Inc.
